Great to see a business putting in the effort!
Thanks Conor, but do we know if the bearing itself is the same?
Brake Calipers might be pricey --- but ill see what we can do...
As for brake disc's can you double check is the diameter of the disc's 280 or 257 mm
Hey LarZ
We do have the front brake calipers ( they are expensive and i would need to double check they are for 280mm)
Front s13 Brake Calipers (Brake System: NISSAN)
We have 280mm in as show below :
ABS
For thirty years, ABS has been renowned as the brakes specialist in the Netherlands.
A.B.S. S13 280mm Brake Disc's
Quinton Hazell
(QH) are the largest aftermarket manufacturer / distributor of motor components in the UK
Q.H. S13 280 Brake Disc's
Rears discs are currently out of stock
Rear A.B.S. S13 264mm Brake Disc's
Brake Pads full range below
Brake Pad range for S13 --- This includes pads for both 257mm and 280mm Disc's
Mintex Brake Pads Fitting Kit
S13 Mintex Brake Pads Fitting Kit
Bit of a long shot but any chance you can source r32 rb20 speedo cable second hand seam to be the only option thanks
