Non vvt black top power fc Ecu with hand commander €450
Z32 maf with apexi air filter (no plug) €110
Sr20det non vvt engine, suspected head gasket failure or head cracked, was dye tested, have spare head bought that will go with it incase head is cracked, comes with rebuild kit, full cometic head set including mls head gasket, cometic bottom end gasket set, acl race bearings and trust washers, and Nissan piston rings €1000 for the lot
0851836338
