Finally got a wing! 1400mm. No such thing as over the top in my book. Just need to make some higher legs.
The car is going back together this weekend, hopefully running on sunday.
1994 mk1 mx5.
Instagram - eoinmarkey
Also, this will be happening again.
1994 mk1 mx5.
this yokes as straight as a roundabout ye queer
Instagram: tom_cullen94
Here is the engine before it went in, looking well.
Here she is going in.
Went in relatively easy. Took time but didnt really run into big problems. Hardest part bar lining up the box was fitting the starter motor in that bastard of a place. Had to take out the rad and move the anti roll bar to get room but no biggy.
All was looking well.
Started it up, eventually. Lots and lots of white smoke, wouldnt idle and wouldnt start again.
I made the mistake of not getting the head skimmed, didnt know it was essential.
So this is how it is now.
and the head is now skimmed.
noice.
Hopefully getting it on tonight and started again. I think the head was the only problem, but we'll find out! Still on target for saturday.
1994 mk1 mx5.
Quick tip leave the box and engine together and take out the rad and they just come straight out. Same going back in you just need to line up the ppf. I dont a clutch at the weekend by taking the lot out. Was handier than trying line up box on the ground.
Everyone was saying that to me. I dont know why I just wasnt arsed unplugging the box haha
1994 mk1 mx5.
Bit of an update. The car is being a right prick. It does not want to start. Takes ages but when it does it sounds smooth and revs nicely.
Havnt taken it for a spin yet though.
Going to try new oil and plugs and see what happens.
1994 mk1 mx5.
The mazda's second coming.
Not starting 100% but getting there. Took her for a spin and it was good, bar the siezed brakes, no power steering and coolant leak, but the engine worked and thats a win. All should be well now for the morning heading to autoheroes. Talk about cutting it short!
Wang isnt on yet, need to make some cross braces to make it more secure. It will look epic though.
Also, hubcaps are back.
1994 mk1 mx5.
Got to autoheroes anyway
Still not starting properly, found out why, the ecu thinks i have 240cc injectors when I actually have 420cc. Silly ecu.
1994 mk1 mx5.
Fitted the wing. Class.
1994 mk1 mx5.
