Results 1 to 10 of 14
    Default Mk4 supra manual gear box and 1jz parts
    I am after a manual w58 gear box from a mk4 supra also the prop shaft , ideally just half that goes into gear box as ive to get custom prop made.
    Also clutch and flywheel to suit w58 to 1jz engine.
    Also after a 1jz manual ecu standard or after market ecu conciderd depending on price.
    Thanks.
    An auto ecu will work with a manual box. What did your engine come out of? The loom plugs are different on the different chassis with 1j's so when looking for a plug and play ecu you need state which chassis you got the engine and loom from.
    Edited: Sorry ive R154 setup not W58
    Default W58
    Hi, if you don't find mk4 supra w58 I have one from mk3supra. Full setup from 7mgte engine. Shifter, crosmember, driveshaft end, fresh oil. 500e
    I will need to check about which chasis the engine came from, i got it off a site member . Thanks for pointing that out to me i wasnt aware of that
    Thanks karos
    I may get back to u about that. Ive been advised to go for the mk4 box as its stronger. And for the conversion im doing i want it right first time around
    Would possibly buy complete mk4 supra if its cheap enough
    Junior member Squire's Avatar
    Kilkenny
    Have ECU here if you still need it...? Came from an Auto Soarer but as above, will work on a Manual
    belfast up north bai
    the ecu he needs is for a vvti 1jz an auto or manual one will do the job
    I have a w58 gearbox from a mk4 supra working perfectly, also 1jz flywheel and ACT 6 puk clutch!
    I have it in my jzx100 and it's working perfect, only reason I'm changing is because I'm going for big power and 6 speed box.
    €1200 for everything
