Hows it goin having alot of trouble tryin the get the correct torque settings for the crank bolts the rods and head can anyone clearify please
I have them on the laptop.. can't remember off hand. Il find out tomorrow for you
Couldn't find the RB20 head bolt settings, but here are the other two. All settings are in Kg.M
Rod Bolts
Crank Bolts (Underlined in red)
Thanks for gettin back to me im fairly new at this and cant really make head nor tale of the measurments 4.5kg.m couldnt be tight enuff is it and i csnt figure out the crank bolt one thanks
If they have 4.5 listed then that is definitely the setting even if it seems low. Are you rebuilding an engine with standard internals or do you have different parts in there?
In what way can you not figure out the crank?
Ye its standard internals just new big ends mains and rings see i dono because 44 nm is nothin it might be my torque wrench but it seams not tight enuff yano
