Results 1 to 3 of 3
    May 2012
    south tipperary
    Default c35 Laurel Medalist huge spec
    any questions PM me here on on FB im on that more often https://www.facebook.com/shane.ofarrell.10
    **FRESH NCT
    **TAXED
    Engine:
    - RB25det series 2, from r33 gtst
    - Cosworth 1.1mm stainless steel head gasket
    - Genuine Greedy Inlet plenum
    - z32 AFM
    - Huge front mount mounted upside down with custom tig welded pipes
    - HKS 25 30 turbo, special KAI edition with anti surge inlet compressor housing
    - HKS actuator
    - HKS stainless turbo elbow
    - full stainless 3" custom home mad exhaust from dairy pipe
    - Stainless pipe from HKS induction kit to the turbo
    - Genuine Nissan timing belt and water pump
    - full genuine head set
    - cylinder head skimmed, new oem valves and valve stem oil seals, acid dipped, ported and polished
    - Splitfire coilpacks
    - NGK bkr 7eix spark plugs
    Fueling:
    - Walbro 255 fuel pump
    - in line high capacity fuel filter
    - Sard adjustible Fuel Pressure Regulator
    - Sard 550cc injectors
    Engine management:
    - Apexi Power FC with hand commander
    - car mapped by West Coast Performance making 326bhp at .9 bar boost, car has zero lag!.
    - DEFI racer series steeper motor boost guage
    Suspension:
    - Front Coilovers are GP sports GR6s camber adjustible top mount
    - Rear Coilovers are D2
    - front DRIFTWORKS tension rods
    - japspeed lengthened and hardened inner and outer track rod end and inner tie rods, pillow ball jointed end
    - rear DRIFTWORKS camber arms
    - rear DRIFTWORKS toe arms
    - rear DRIFTWORKS castor arms
    - rear DRIFTWORKS subframe bushings
    - rear DRIFTWORKS diff solid bushings
    - front of rear diff has japspeed poly bushes
    - car completely stripped bare under neath and undersealed, its like new
    - 2 way cusco diff with castrol b373 diff oil (4:1)
    Brakes:
    - standard rear callipers
    - handbrake on shoes, new shoes fitted and got discs skimmed
    - r33 front 4 pot brake callipers , sand blasted and painted origional colour
    - skimmed front oem brake discs with upgraded pads
    - goodbridge braided brake lines
    Wheels:
    - SSR professors all round
    - 25mm DRIFTWORKS bolt on hubcentric front wheel spacers
    - 18x9.5 +18 on rear
    - 18x8 +33 on front
    Exterior:
    - brand new BN replica front bumper
    - LED front indicators hidden nicely in the bumper
    - two number plate bilt bars!
    - Euro skirts and rear bumper
    - 4" dairy stainless exhaust tip
    - wind deflectors
    - tinted windows on the rear
    - chrome door handles and all wondow trims
    Transmission:
    - rb25 det r33 5 speed manual gearbox conversion from automatic
    - exeedy stage 2 3puk clutch
    - exeedy 6.5kg lightened flywheel
    - castrol 75w90 gearbox oil
    - i wired up reverse sensor into origional loom so reverse beeper and dash R light works!
    Interior:
    - kept it pretty origional
    - car has standard seats with side air bags and eletric motors for adjusting
    - defi racer boost guage
    - dmax style coffee VIP table
    - FC commander mounted to dash
    - shag style nissan accessery interior matts (have 2 sets)
    - double DIN touch screen DVD / TV / sat nav , controls heaters , CD player, Aux inlets ect..
    - Razo gear knob
    - vanity mirrors
    - has has auto head lights, knows when its dark, also dims dash bulb
    May 2012
    south tipperary
    bump...
    May 2012
    south tipperary
    for sale again.. bump
