    Aug 2011
    Default rb20det and rb23det
    rb20det
    Currently in car, can be seen running and driving
    Comes with:
    full engine with head etc
    inlet and exhaust manifolds
    standard rb20 turbo
    injectors
    New timing belt , water pump, oil pump and headgasket along with head rebuild at 175k , now at 194kish
    850 euro
    rb23det build
    Head is there and complete
    Engine was running in an r32 but taken out due to using oil
    Rb20 block bored out to 83mm
    Now using Mazda BP pistons and standard rods
    Oil squirters modified
    Crank has been polished and balanced
    n1 oil pump (used)
    engine currently broken down for rebuild
    no turbo , loom or ancillaries
    Comes with brand new ACL rod bearings (standard size) for rb20 and 2 set of 4 new Hastings piston rings
    450 euroeuro
    Aug 2011
    bump!!
