have a 2jz turbo block here.. was initially bought for 1.5 jz build.. engine was lying outside and got water in to plugs.. i took the head off and dumped it.. so just the bottom end here.. good crank etc.. would be ideal for someone wanting to build a 1.5jz €SOLD
Also have..
1 JZ Non VVT Engine With Front Sump, Fresh Oil Pump, Great crank and head etc.. Used At Round 1 IDC this year.. Valve Seals Needed As engine was slightly smokey.. This is located in wicklow atm and the head is off the engine.
SOLD..
Bosch 044 Motorsport Pump Only Used For testing- €120
