    Default 1jz, r154, tech 2 for s body
    I'm selling my front sump 1jz non vvti with r154 and a full tech 2 kit, it'll bolt into a s13/s14/s15. The kit includes a new front cross member, engine mounts, gearbox mount frame, single piece prop. Also includes a modified 50mm rad with hoses to suit the conversion.
    The engine will come with 2 sets of turbos. Stainless y-pipe. Full engine loom and ecu.
    The whole lot is ready to bolt in. It just needs wiring and plumbing.
    The engine was only test fitted to my s14 it had new bottom end bearing fitted when the front sump was being fitted, it didn't need them but as it was out it was the best time to do it. It also had a full Toyota gasket kit fitted at the same time.
    I can include at extra cost a GReddy front mount with piping to suit the 1jz as well (you'd need to get a 90deg hose to complete the kit).
    I can also include Dakota digital boxes that will convert the speedo and Rev counter to work correctly on the 1j.
    There is a lot going with this. I don't want to split it unless it can all go at the same time.
    I'm asking €3000 for the complete kit including the front mount and Dakota digital boxes. I'm open to offers on it but no stupid prices.
    Sold.
