Results 1 to 3 of 3
Thread: D-Mac 86!!!
    Pro Driver
    Default D-Mac 86!!!
    The infamous D-Mac86 built for the Need for Speed Shift 2 computer game and campaigned by Darren D-Mac McNamara throughout Europe.
    Built to be the craziest AE86 on the planet!!
    Spec as follows....
    Chassis:
    Built by MCNSPORT from 1983 jdm import ae86
    Seam welded
    Extensive metal removal
    Multipoint weld in rollcage
    Front and rear tube frame extensions
    Rear mounting points for Silvia IRS subframe
    Painted metallic silver
    Engine:
    Hayward Rotary 13B-REW
    Hayward Apex Seals
    Hayward Bridgeport
    Martelius ceramic coated lower and upper inlet manifolds
    Custom dry sump kit
    550cc primary injectors
    1600cc secondary injectors
    Custom secondary fuel rail
    Aeromotive FPR with gauge
    Martelius ceramic coated custom exhaust manifold
    Tial 60mm wastegate
    Martelius ceramic coated screamer pipe
    FD3S coils
    NGK race plugs
    Magnecor plug leads
    Custom altenator relocation
    Water pump delete kit (electric water pump in rear)
    Martelius ceramic coated coolant pipes (hot pipe coated with thermal dispersant and cold pipe with thermal insulator)
    Panspeed intake elbow
    Apexi Power FC
    Apexi Power Fc Commander
    Garrett GTX35 turbo
    K&N air filter
    Cooling:
    HPI intercooler
    Custom intercooler piping with Wiggens clamps
    Custom Mishimoto radiator
    Twin Kenlowe radiator fans
    Mishimoto radiator cowling
    Davies Craig electric water pump
    Samco Sport silicone hoses
    FC3S oil cooler
    Transmission:
    Saenz 6 speed sequential gearbox
    Saenz tunnel mounted gear lever with reverse detent
    Gear indicator on dash
    ACT Xtreme single plate clutch kit with flywheel
    FC3S Turbo II bellhousing
    FC3S Turbo II clutch slave cylinder, fork and release bearing
    Custom one piece driveshaft
    Suspension:
    D-Mac front lower control arms
    Aftermarket tension rod relocation brackets
    D-Mac steering knuckles
    D-Mac outer tie rods
    D-Mac offset rack spacers
    Ae86 power steering rack
    SW20 electric power steering pump
    Whiteline adjustable front anti roll bar
    Alloy front hubs
    D-Mac/AVO front coilovers
    Modified Cusco camber tops
    Highly modified Silvia S14 rear subframe
    D-Mac rear lower control arms
    D-Mac rear camber arms
    D-Mac rear toe arms
    D-Mac rear traction arms
    Whiteline adjustable rear anti roll bar
    Driftworks rear drop knuckles
    Locked differential
    Solid subframe bushes
    D-Mac/AVO rear coilovers
    Aero:
    D-Mac frp front fenders
    D-Mac frp rear quarters
    D-Mac frp doors
    D-Mac custom frp roof with cockpit air intake and rear radiator intake
    Carbon fibre rear quarter windows with rear radiator intakes
    D-Mac N3 overfenders
    BN Sports Sideskirts
    AE86 zenki rear bumper
    D-Mac frp rear tail light shell
    D-Mac frp tailgate
    Goodline frp bonnet
    D-Mac frp headlight covers
    Garage BB rear GT wing and mounts
    Polycarbonate rear window and door windows
    Brakes:
    Custom 296mm floating front disks with alloy bells
    Rear EBC BNR32 disks
    BNR32 calipers all round
    ASD hydraulic handbrake
    Steel braided lines from front to rear
    Z32 master cylinder
    AE86 servo
    Front line lock
    EBC pads all round
    Interior:
    Cobra Suzuka bucket seat
    TRS harnesses
    Sparco steering wheel
    Sparco clip off boss
    Custom stainless steel steering column
    Carbo Fibre dash
    Defi tachometer
    Defi BF boost, water temp and oil pressure gauges
    Defi gauge controller
    Sparco master switch
    Apexi Power FC
    Apexi AVC-R
    SW20 power steering pump and reservior
    OBP 1.5 gallon dry sump tank
    Alloy drivers footrest
    Alloy co-drivers footrest
    Front brakes line lock
    Plumbed in fire ex system
    Wheels and tyres:
    Work Seeker CX wheels
    Front 17x9.5
    Rear 18x10
    Falken RT615K 235/40/17 fronts
    Falken RT615K 265/35/18 rears
    Fuel system:
    Custom 20litre fuel tank
    Bosch 044 fuel pump
    Sytec bullet fuel filter
    Carbon fibre firewall
    In- car video on Facebook:
    https://www.facebook.com/video.php?v...type=2&theater
    Performance:
    500hp @8500rpm
    Max rpm 10,000
    959kg
    52% nose weight
    €40,000
    NOTE:
    Car is available as a rolling chassis with engine, gearbox, dry sump system and intercooler removed for €15,000.
    For your own engine and transmission and have a professional spec car second to none
    MCNSPORT can also fit an engine and transmission of your choosing to the rolling chassis
    mcnsport@gmail.com for queries.
    di Member Deco84's Avatar
    Oct 2009
    Dublin North/West
    C'mon ........ Euromillions
    We can't stop here this is bat country
    di Member michealkirwan's Avatar
    Jan 2013
    kilkenny
    Holy fuck you mean!! .. sorry to spam but cmon ... holy fuck!
