hey lads,
just bought a e30 there and have 318is e36 running here
what do i need to change?
mounts?
sump?
gearbox?
prop?
etc?
hey lads,
mounts?
sump?
gearbox?
prop?
etc?
What engine is in the e30 at the moment.
Minimum you will need is engine mounts, upper and lower sump, e30 exhaust including manifold. Inlet manifold and the engine loom. Is the iS engine 1.9 or 1.8. If its 1.9 you are wasting your time because its just too much hassle to fit.
you'll see why when you try to fit it :P
you'll also need the cam cover because the breather pipe is in a different location on the e30 and e36's.
if you tell me what engine is in your e30 i'll tell you everything you will need
Sell off the 318is engine and put a proper engine worth the effort into it![]()
yah i'd say im best off buying a complete 325 running aren't i? ha
anybody have a complete running gear
engine
box
mounts
loom
etc.
