Results 1 to 8 of 8
Thread: S15 sr21
    Jun 2011
    Default S15 sr21
    Been knocking around the site with a few years and 7 Honda's later i decided to jump on the band wagon. Taught it wise to buy something sensible for my first rwd
    Car is only mapped for the road at the moment and just recently flew through the nct. However a bit more power is going to be unleashed from her
    Nissan Silvia S15 Spec R
    355.2 bhp at 1.44 bar
    Mapped by TDP.ie
    PERFORMANCE:
    S14 non vvti engine
    S15 6 speed gearbox
    HKS 272 intake camshaft
    HKS 264 outlet camshaft
    HKS rocker arm stopper
    HKS adjustable cam pulleys
    HKS valve springs
    HKS steel head gasket
    HKS 2.1 forged piston kit
    Head ported and polished
    ACL race bearings
    ARP head bolts and main studs
    Apexi AX53B70 turbo
    Braided turbo lines
    555cc nismo injectors
    Z32 air flow meter
    Blitz air filter
    Hanshin coil-packs
    Apexi Power FC ECU
    Exeedy stage 3 puk clutch
    Driftworks solid lightened flywheel
    Baffeled ARP high capacity sump with steel belly pan underneat
    Apexi turbo elbow
    Full Silence Hi Power exhaust system including manifold, down pipe, decat.
    Front mount intercooler 80mm
    Samco Sport boost pipe silicon hoses
    Aluminium radiator 45mm
    Over Rev Group radiator silicon hoses
    Twin electric cooling fans shroud on with thermostatic switch
    Carbon fibre cooling plate
    Carbon fibre/aluminium ABS pump heat shield
    Earthing kit
    Air conditioning removed
    Gates axillary belts
    SUSPENSION/WHEELS
    Driftworks castor, camber, toe, lower control arms and tension rods
    Cusco 2 way diff
    EBC drilled and grooved discs
    Yellow stuff pads
    Dynamo front coilovers with adjustable top mounts (damper, camber, height)
    Apex rear coilovers (damper, height)
    25mm wheel spacers on front
    Ultralite 10.5” wheels on the rear
    Vertex VRS Manatray Sport 8.5” wheels on the front
    INTERIOR:
    DEPO Racing Japan water temp, oil temp, oil pressure, boost gauages.
    Gizzmo boost controller
    Blitz turbo timer
    OEM boot strut brace
    Battery relocated to boot
    Drift button on handbrake
    Wilwood hydraulic handbrake
    Driftworks hydraulic handbrake lines
    Interior B Pillar lower floor brace
    Full original Spec R black interior including electric windows, steering wheel, seats, gear knob, mats etc.
    Navigation system with flip up screen on dash, CD, MD and climate control.
    EXTERIOR:
    N1 front bumper
    Uras side skirts
    Uras Rear Bumper
    Origional front headlights
    HID's low and high beam
    LED rear lights
    OEM wind deflectors
    OEM boot spoiler with brake light
    Rear window wiper
    Tinted 3 rear windows
    Original Silvia and Spec R badges
