    Default re e60 m5 manual conversion
    How are things lads looking for a ball park figure on converting an e60 m5 to 6 speed what kind of fabrication costs can pick up a getrag out of a e90 e92 s65 fairly handy have 5000 and that's the absolute Max including the purchase of the box
    Cork
    Not really sure why you'd want to do it but it'll have very little fabrication anyway as the S65 box bolts straight on other than sorting out gear linkages and prop-shaft lengths and obviously need the clutch pedal box and cylinders from an manual E60
    You'll need to flash the ECU then as well to not look for gearbox inputs.
    Seems abit odd really though as the M5 as it is with the 7 speed DSG works the finest
