this was how it started. . r34 4 door. rb20neo with auto box, standard wheels. standard everything
so started by upgrading the car a little. . so first few buys set of r33 4pot and two pot brakes, set of 9.5 18" rota gtrs and a set of hsd coilovers.
so next of course the auto box had to go!! put in a r33 gtst manual box. fitted perfect with no issues. while putting it in I changed the diff out for an s15 LSD for now. diff and gearbox mounts and all bolts lined up perfect. skylines are like lego ha. The clutch choice was an os giken twin plate clutch for what came next. . the rbneo didn't really light it up![]()
where do you go from there engine of course. . the choice
rb26dett from an r32 in from japan. decided to ditch the twin turbos and go for a top mount single
it was a job to get it in right and the way I wanted it. . so a lot of time and money later it is in
so some pics of the upgrade
rb26 with greddy top mount turbo, greddy manifold and greddy external waste gate.
full custom stainless exhaust
oversized from mount with custom piping.
upgraded walboro fuel pump and fpr sard. 550cc injectors.
splitfire coilpacks and iridium plugs.
upgraded all bearings, big ends and mains acl race bearings.
new N1 oil and water pump with HKS Kevlar timing belt.
HKS cam pulleys.
Jperformance alluminum rad and silicon hoses.
most important link plug in G4 ecu with boost solenoid, map sensor and wideband lamda
I went up to buy this and the same day I went to look at a 4 door 32. ended up with the 32 but nearly bought it =[ I need a 34. fairplay. you seem to be going the right route with it
team ball bag
thanx for not buying it ha!! im starting to get there now
Sweet, wouldn't mind starting out with a similar base, bests luck
Yahoo another 4 door Nissan for the road, I'd love to have a R34 moredoor!!!
Serious time and money gone into this thing fair play..Best of luck and enjoy the fuck out of it
