Results 1 to 10 of 17
    di Member Sideways Simon....'s Avatar
    Mayo
    @ e36h26- them instructions only apply to the ibc
    The gizzmo ms-ibc is different set up-
    The ms-ibc is the one with the black box and blue numbers.
    the ibc has a silver box with black face and i think its green numbers.
    I have the ms-ibc and its fine, does exactly what it does, has a scramble button for quick boost changes and has a anti spike feature and a over boost setting.
    There pretty easy to set up , just take your time, read the instructiions a few times.
    Anyhow to set boost...
    >press and hold down the bottom button
    >Then press the bottom button to select open
    >press both buttons together, then it will flash "duty"
    >use the top button to set the duty at 38( change this up or down to change boos level)
    >press both buttons together, this will then bring up "gain" on the display
    > using the top or bottom button set the gain to 10-15 but on a standard turbo 15 is more than enough, or else the chances of a boost spike is more likely. I have mine set at 13
    >next press both buttons again and thats it set up.
    Go out the road and check your max boost in 3rd and 4th gear and if its too low just increase the duty or if its boosting too high decrease the duty. but only make small changes to the duty at a time.
    The duty levels will be different in every engine.
    Quote Originally Posted by Sideways Simon.... View Post
    Suppose we shouldve asked which one hes running, and i was too lazy to type it all out for the MS-IBC
    Ennis
    Anyone know if the ms-ibc settings are the same for the newly released MS-2?
    any quick tips for that unit?
    Cheers lads,forgot to metion that it was the MS-IBC one.
    But when i change the duty (between 10 and 28 the boost stays at .98)didnt want to go any higher until i made sure, but most go higher later and c.
    Mayo
    Quote Originally Posted by SteveM View Post
    Do you have an adjustable actuator by chance??? and are you sure its the duty your changing and not the gain??
    Its the duty alright.there is actually the lad i got the car off had a fordge one fitted.
    But i taught if i fitted a boost controller wouldnt have to go at it.
    Im wrong obviously am i?
    Mayo
    Well the boost pressure of a standard actuator on a t28 is just a tad under 0.5 bar.. the previous owner may have the adjustable actuator adjusted so that its 0.9, if so the boost controller wont go below that... So, whatever the pressure is at the actuator the ebc wont go below that...
    Fair play,most go set that lower so.
    Nice one.
