Results 1 to 3 of 3
Thread: s14a 1JZ
    Aug 2010
    Default s14a 1JZ
    cant see me finishing this any time soon so here goes .. wats listed is as Is txts only calls after 6 please 0876372348
    1jz front sumped engine s14 conversion mounts wit solid mounts 180kms when removed .. custom rocker covers with braid breather pipes.inlet injectors coilpacks alternator pas pump wiring loom ecu etc all complete .. 1200e
    r154 gearbox with shifter and s14a mount . s14 prop act clutch , flywheel slave ect full conversion 1600e
    gt3076 twin scroll .82 rear housing antisurge housing with braided lines to suit 1jz stainless vband downpipe aslo turbo has done 4 events .. 950e
    toyosports manifold with 60mm wastegate .. 350e
    japspeed 100mm alloy rad brand new 250e
    4inch k.n filter new 60e
    cusco coilovers needs 1 front top mount 350e
    rear subframe with tdp bushings and camber toe and traction arms 250e
    skyline twin pot callipers and discs 170e
    extra lock by gem synott rack forward cut hubs. adj tension rods hardrace tie rods s14 lower arms 250e
    s14a shell wrc style cage bigger tunnel 500
    group4 tank 25 ltr new 044 pump 400
    4 defi replica gauges 200e
    battery box new 50e
    four rota torques 17x9.5 et12 450e clean wheels
    2 ultralite battles 17x9 et20 150e
    please no timewasters .. most of the stuff is costing me a lot more .. 0876372348
    Member
    Dec 2012
    Pics on the shell
    Aug 2010
    No pics on ds can send om Facebook
