Results 1 to 10 of 13
    its not low enough!
    If u can find one cheap. They usually make good money , yea u cab buy rebuilt kits, on eBay
    MEATH
    Neo turbo's are not steel and will blow just as quick as S1 and S2-
    Steel Core hybrid are approx 350-450 any of your polish friends should be able to get one done for that, wasting money on a stock RB turbo
    its not low enough!
    i always thaut neos had steel blades an not ceramic?! good to no !
    MEATH
    There a kinda mix of ceramic and plastic :confused
    They still don't take boost either way, you'll find the impellar bunged into the cat core like all the rest
    All RB turbos are ball bearing, hence the Oil Feed banjo restrictor being so small.
    RB Neo Turbos have a plastic compressor wheel and ceramic turbine wheel, this is why they spool faster than the earlier turbos. They also have a bigger exhaust housing than other RBs. You should get 1 bar safe on any RB turbo.
    di Member GTSr32's Avatar
    no not all RB turbos are bb at all..!
    in a perfect world id get a RB25 neo turbo redone with steel internals ... But a normal rb25 with steel internal will do you nicely...
