Results 1 to 10 of 25
    Default v86 build (1uz+ae86)
    built this wee corolla to replace the pink car which i regret selling ever since the fella left the depost on it
    fitted it with 20v and done a trackday and busted the gearbox right away so it g parked up since
    wilst it was parked up i went to the darkside and bought myself a s14,
    great car power to no end and the powersteering was nice but.....it felt so wrong who was i trying to kid, im a corolla man and always will be so... with the nissan out of me and my self shook into shape again i needed to come up with something which is different on this island and something whichis going to give me a nice blend of power and that all important n/a charicteristics for reliability(im not a forced induction man its just my style of ignorant driving)
    ls400 it is then for me to rob of its v8 powerplant (thanks to barry mccardle)
    1uzfe 2nd generation 262bhp and torque of 363 N·m (268 lb·ft)
    https://www.facebook.com/photo.php?v...16203837564671
    im hoping to have this out for test run in 3 weeks for the ae86irl meet in tullow if it proves right for me its stripped and rebuilt for next years drift season
    yeah for thwe time being im going to stick with standard then see how things go, im accually going to fit the ls clocks so ill just delete from the origional loom whats not needed and fit all into the corolla should leave it real handy,
    engine, loom, ecu, clocks all removed not from the donor ls400
    started making a 2mm template for a adapter plate and all seems to be alligning up spot on, so wil transfer this to 10mm plate now, adapter is to go from 1uzfe-w85 i wanted to keepthe w58 bell housing and clutch for for maintance reasons
    with the festive season over and a bit of a accident in the family i havnt got much done so its time to get back at this again, decide to get the front of the car benched as it had a previous damage to the front leg so its goin away monday to get that done, with it being previous rally car some muppet painted the inside and bay white and with it chipping off it is a real dogs dinner,,one of my hates is white interior n engine bay. after benching ill finish the front its getting a tube frame front and then blasted and painted
    gearbox mount made, rubber mount from altezza fits the w58
    tunnel mod so i can remove the gearbox easily trackside
    adapter made for gearbox, w58, 3sgte flywheel and pressure plate
    brake booster delete, i decided to run the front only brakes via pedal and rear via hydro handbrake, so made a plate to use a handbrake cylinder and will add a resovoir
    hopefully some progress in the 2 weeks time as ive to start back monday at a wee evo for sc or he will have a child
    getting there
    ae86 left vs terrano right
    yeah running just fronts on the pedal and the rears off the hydro
    axle getting narrowed,,
    as i said above somewhere i needed to find a replacement axle as the little ae86 wouldnt be up to the task of the v8 so i sourced a terrano/maverick axle thery come with a very reliable lsd unit stock, they have a huge 9" ring gear.
    the axle was 35mm wider each side so ive decided rather than arch the car i decided to narrow the axle 25mm each side the other 10mm will come of the mounting face of my rims!,
    first was the halfshafts taking off 25mm, when i pulled them out and measured i measured 25mm from end of shaft in it came to the end of the splines which was being used, then whe i measured what splines was accually being used was 18mm,,, so i just got the 25mm lathed off and this left me with still 18mm of splines the same as before, also has to lathe down a section after the splines top let the shaft slide onto the side gears in the diff unit.
    next was pcd for 4x114 so get the pcd drilled and tapped 12x1.25 so i can screw in studs and weld the backs of them for extra strength! also got the drums drilled 4stud
    next off was the axle, simple enough just lathe off both ends and take 25mm off them, them ill insert the hafshafts and diff unit to get the ends lined up perfect again before welding!
    should be sweet
    next up is make a jig for putting on the mounting brackets!
    axle fab work complete
    next axle in and onto making the flare arches
    wee bit of painting going on
    love the v8 power, 1st gear was no use had to start off in 2nd
    Limerick
    Saw the vids up on DW, sounds awesome !
    Jul 2010
    Tipperary
    Cool build man. Didn't gripfab do a fc build with the same V8
