    Junior Member
    Nov 2013
    Default lexus is200 volt problem need help
    I recently bought is200 with clutch gone put in a clutch and and now have a problem with volts only reading 11.80 volts and is discharging battrie tried alternator 4of them including one out of a 2jz and still the same problem ...its not the battrie have tried 3 of them any1 have this problem before ..? How toni fix it
    Kilkenny
    Did you break any earths off the car. ? the belt tight on the altenator ? Any wires pinched ? my rear lights reverse light wire was pinched and it made the car drop to 10 volts and when i unpinched it it went back up to 14.4 volts.
    Id check for broken earths first then pinched or broken wires hitting chassis first then if nothing like that then altenater belt if touched is not tight enough
