Results 1 to 3 of 3
    Default hydraulic handbrake wit abs
    Just wondering is anyone usin a hydraulic handbrake in a car wit abs? Does it work to plumb in the hydro after the abs unit? Gonna put one in the s14 but don't wanna take out da abs
    Cork
    yep, will work fine. just plumb it into the rear brake-line as per usual.
    Be careful though if using the hydro with the ABS working though as you won't have much brakes when you try to lock the rear wheels as the abs will see it as the back wheels skidding.
    Best thing to do is fit a switch so you can turn off the ABS when you want.
    Sound for that dave
