Results 1 to 7 of 7
    Mar 2011
    Default s14 UK spec won't start nats problem
    We'll lads
    Iv a 94 UK spec s14 the nats anti theft system don't let my car start any ideas on how to get it goin it's turning ova but won't fire up the remote for the alarm is still working fine any ideas would be a big help tanks
    Member
    Jan 2012
    Donegal
    Standard alarm only ?
    Red light going out in Dash ?
    Have you checked fuel pump fuse in driver foot well ?
    Also if you are sure that it is nats, there is one/two nats boxes in rear passenger side, remove trim around / under window, you will see two boxes there ,with fuses, check those.
    Presume you have checked all fuses, wiring and narrowed it down to actually the nats?
    Car lowered ?
    Check under driver wing for broken , eaten wires etc?
    Mar 2011
    Quote Originally Posted by Void_The_Warranty View Post
    Car lowered ?
    yea standard alarm only and iv tried all these my friend wanted to try his ecu in my car and wen i tuck the ecu out and put it back in it wont start it was running fine before hand any help would be appreciated
    Cork
    try resyncing the fob with the car.maybe when you took out the ecu it caused a problem with the immobiliser
    Mar 2011
    Quote Originally Posted by jamesd View Post
    Cheers lad do you've any idea how to do dat
