Wet rub only thing that gets rid of reactions or maybe good coat of primer, but once had a spurious spoiler for
A passat that had to skim the hole thing with filler to stop reactions
you see, ive painted wings , skirts and a front bumper and have had no problem so i dont think its a compressor issue, i even painted the skirts after the overs on the same day and no issue! thanks for the input tho man
had a good coat of primer! maybe will need more tho
There's an anti-silicone you can add to the paint
ya if you've painted other parts with no problem then it's the panel. you might consider barcoating it.
fire up a pic to we see,, is your compressor close to where you are painting?? they exhaust a lot of oil vapour,,
ah well that rules that out<< have you bled it lately and do you have a water trap,,
even with my one fitted at the bodyshop I used to get the odd re-action, more so with white for some reason, fitted a wee filter at the gun also and that stopped all,,
http://i.ebayimg.com/t/Spray-Gun-Air...,PR-Q~~_35.JPG
