Results 1 to 5 of 5
    Mar 2013
    Default Clutch replacement ideas
    Hi, have a 523i and finally blew the clutch after its 5th drift day, to the point that it actually melted it to bits!!, wondering whats the best clutch to get, was thinking a heavy duty one, or has any other people any ideas thanks
    Donegal
    Stock clutch is all you need
    Mar 2013
    would i be better not putting in a heavy juty one as i hope to do mondello a few times along with the other track days, while i have it out like!? thanks
    Donegal
    Your still runing standardish hp so the std clutch will do fine.
    Starting to see more and more lads taking their uprated clutchs back out and
    replacing them with std clutchs, as their fed up braking boxs and other
    drivetrain.
    When you have the clutch out ya should bring youre flywheel to a machine
    shop to get it lightened and balanced.
    Edit
    Which model of 5series have you?
    Doest it have a dual mass flywheel?
    Mar 2013
    Ill go with the standard one so i will do there wasno damage to it. Its a 523i lad
