Also the Gold sticker on the drivers window is Midnight in Japanese!!!![]()
Jeez man thats some crazy story! Im actually thrilled to hear this back, its what i was hoping for by making a build thread. Was it originally imported like it was in red? With all that kit on it? And what year did you import it in?
Powder coated my bonnet hinges matt black in work today just to see what theyd come out like. Joys of having access to the powder coating booth and oven in my factory! Think I'll use that more often....
So one of my mates managed to get their hands on a crane a little earlier today. So we said we'd make a burst into it and take out his 180sx engine and mine. Not too much hassle at all taking it out.
Stripped my interior whilst waiting on him to arrive with the crane, found the sound denting had already been removed in the back....
Showed no signs of rust at all, but did finally reveal the factory colour we had suspicions that it was....
Sorted most of the crazy wiring underneath...
Began whipping out his engine...
Took out my turbo and manifold....
Found out I actually have an s15 turbo...
Compared the turbo in the 180 to mine....
And finally got out mine!
And thats a wrap for tonight, two sr's out and two naked s chassis' ready for engine bay prep work. Cant wait to get cracking on it. Still very undecided about a colour. Go crazy or keep it simple...? Hmmmm....
Paint the engine bay a pearl or mettalic grey! Its simple and classy looking in any well maintained engine bay or interior!
I think I Imported it in around 2006/2007.
It was a similar crazy kinda of pearl red that no fecking panel beater seemed to be able to match,so a local bodyshop done up that colour you see it in the pic at Japfest.It was a candy red with gold kind of metalic underneath (wasn't the best of paintjobs mind) but when the sun was shining it was mental.
I think the picture above was in taken in Japfest 2007.
Crazy to think some tool wrecked that car.Car was imported otherwise exactly as you see in the Japfest pic.Kazama Auto didn't really do things by halfs,only mod i needed to do was the respray.
Return it to her former glory bud.People still talk to me today about that S14.
This is music to my ears, at what stage did someone start taking out the goodies then, like the power FC and that, there's none of that malarkey in it now unfortunately, and what was the story with the internals of the engine??
From what i remember ALOT of Tomei and GReddy stuff in that car when i had it, Tomei cam's,Injectoers,G Reddy turbo,manifold and intake,forged internals,......but who knows might not even be the same engine as the time i had it,just simply the engine cover moved over.
Been busy past couple days giving a hand here and there to the other lads and havent really got to mine to make any more real changes.
We burned out the bushes on one of the 180's.
Fitted all new arms and polybushes, hoping to do this to my own soon....
Started proper looking into my own car to try make heads or tails of the past stories, found some very good evidence as to what may have happened it.....
Came from Charleville anyway....
Finally found some rust when I searched high and low on it, the usual 14 boot well, easy fix...
Makes me sad that previous red glowing up at me....
Cant wait to get at that battery bracket with an angle grinder and get sanding the engine bay...
Nice little after market anti roll bar...
That colour glowing at me again made me look even deeper into things....
And think I found the reason why it was sprayed white... She mustve got a tap! Poorly beaten out with a hammer but handy enough with filler... Guess that red colour was too dear to match and ended up doing it on the cheap... Which came in the colour white...
Hopefully dropping the subframes in the next two days. Then shultz the underneath and paint up the subframes... Get cracking on the engine bay then.![]()
what about the big hole in the block the conrod made from drifting it down the port with the big ends rattling xmas day![]()
Have been busy the past while and havent really got a chance to update this, we extended the new unit and 4 more of our buttys have moved in so its been all hands on board the past while. Heres the update....
Picked myself up a mint Sr20det, straight out of a 180 brought in from Japan that hadnt even been vrtd yet. 60k miles. Loom currently been sourced for me by Japenese Performance....
Cracked open my old gearbox to find a nice little ORC Ogura clutch....
Unfortunately, part of the deal with the new engine was he got to keep the box and clutch.... Dammnit....
Got into the new part of the unit and work got immediately underway....
Front subframes got dropped
Stripping back of the major surface rust began....
Got the arches back to get a proper look at where it needed to be rewelded...
Only one way of tidying up this, and its off to get tubbed in the coming week or two!
Etch Primed & High Build Primed what I had ground back to bring up a smooth finish...
Quick spray of stone chip sheild for the time being....
Now to do something with the inside....
Quick wire brush and Etch Prime...
Small bit of welding in the boot and a quick wire brush back, high build primer and a lick of raincoat... Tidied up a small bit I suppose...
Out came the back subframe...
Found some solid bushings already put in.... welded in I may add... the japs mean business....
Hupppp she goes' ...!
Nice wire brushing and a healthy coat of Schultz... Lick of clear coat to harden it up now today....
Even the gearboxes got a little TLC...
Hopefully off to be tubbed in the next fortnight, in the meantime subframes will be stripped, cleaned and repainted... and treated to some new polybushes.
