Well lads I've a bit of a problem with my Spec S. She's running really rough when cold and the very odd time when hot. When its cold it struggles to rev and nearly cuts out sometimes. When I clutch it and rev it seems to rev fine. When its hot I get sudden drops in power that feel like the engine is coughing almost. This goes away after a couple of 'coughs' and shes back to normal.
I'm thinking that its a problem with one of the following:
Spark Plugs
Leads
Distributor
Fuel Pump
Fuel injectors
AFM
Does it sound like a problem casued by one of the above not working properly?
Another possibility might be the clutch, but I doubt its this because if it was the clutch then the engine would rev up as the clutch slips ya?
Any help with pin pointing the problem would be great lads. Sound
