Once there's no pump , light or sensors it should pass 100%
small bit or wire and wire the bulb to the oil light/etc on the cluster it will turn off when the oil light turns off
team ball bag
Could he not just pull out the fuse for the abs when he wants it off and put it back in for normal driving, i've read about lads doing that with silvia's and it works no problem, could be different on an is200... Worth a try though,
You could even put it on a switch...
depends on how cute the testers are.. i know few testers and the smart ones know when u turn on the ignition the ABS does a check and after usually 5secs the abs light goes off even with the engine off, so they can check if its wired off the oil pressure switch or anything else.. there not really failing on it much but be aware they could.. they failed me on the laurel last test for having the pump and sensors and no ABS light, wankers, twas easily sorted but still hassle.. its a fuckin money racket..
If it's not there How can they test it? Once you take the bulb out too they shouldn't notice.
my car has abs turned off. pump still there as is the sticker on rear window.
abs light deleted from dashboard
passed nct twice with no problems
