Results 1 to 4 of 4
Thread: rear fog light
    Member
    Mar 2012
    Co.Waterford
    Default rear fog light
    Well im going for nct next week and the car has no rear fog light could it fail on that ?
    "If in doubt, flat out" - Colin McRae
    No jap imports have rear fog lights unless they were in the uk
    Member
    Mar 2012
    Co.Waterford
    Thanks for that
    Junior member patapon's Avatar
    Dec 2010
    get a changer relay mate.
    this is how I did it on my 180sx kouki so that I havent had to dismiss my inner brakelights.
    pinout:
    30 brake light RHD right inner bulb
    85 negative ground
    86 ignition + this is were you want to wire in a switch.
    87 constant +
    87a wire that connected to the brake light
    now you have a seperate controllable brake light wich wont short out once you brake or turn you lights on.
    also might wanna wire in a fuse.
    for a s13 you can buy a oem fog light switch to keep everything neet.
