Results 1 to 7 of 7
    Junior Member
    Aug 2013
    Default Diff for ta23 celica
    just putting it out there, looking for diff for celica ta23
    not sure what fits(seen ae86 diff used) so maybe some out there might be able to help
    May 2012
    Thumb tack castle
    Check what axle is fitted to yours should say "f" on the id plate in the engine bay, like my ta22&23. That would make it easier to cross reference what fits
    Junior Member
    Aug 2013
    it says trans/axel T50
    May 2012
    Thumb tack castle
    Its the next few digits after t50
    Junior Member
    Aug 2013
    ok so the full code is t50 t292
    May 2012
    Thumb tack castle
    T50 is your gearbox type and t292 is the axle type, early ae86 should fit you can confirm this by counting the teeth on the half shafts.
    Found this http://www.ebay.ie/itm/Toyota-Celica...item3f2e17a6d5
    Junior Member
    Aug 2013
    thanks for the help, wow they are not cheap, that ones a fare bit outta my budget but its given me a starting point
    Thanks once again
