Ecu is a nistune,car was stalling before the remap.
Could I be losing vacuum through one of the pipes for boost controller or one of the pipes going to the evap can?
Could be any of these man,
air intake system/vacuum system - leaks
idle air control value (IAC)
engine coolant temp sensor (ECT)
throttle position sensor (TP)
mass air flow sensor (MAF)
injectors
fuel pressure /delivery rate /fuel pressure regulator
engine management system- wiring/connections
engine control module (ECM)
Mac C that list is painfull lol
I'll start working through the list straight after work tomorrow, once I know what to check it makes life so much more less stressful plus I've being rebuilding the car for the last 18months so it really needs to be finished
Thanks
