Results 1 to 7 of 7
Thread: Temp. Rising.
    Senior Member derekmcl05's Avatar
    Feb 2012
    Ballymoney
    Temp issue is coolant flow problem, check your radiator is flowing properly and not blocked, also check your radiator is in good condition, alloy radiator may be the answer, also check your thermostat is opening
    missing before 3k rpm could be plugs or lambda sensor or a few other sensors, best to do a self diagnostic with the ecu if its a Nissan
    di Member Andrew200sx's Avatar
    Sep 2013
    Co.Louth
    Derekmcl05 thanks for the info. Will have a look at it tomoro. Forgot to mention cars a nissan 200sx turbo.
    Feb 2013
    Ya definetly get ur rad pressure tested to see if she isent blocked at some stage and take out ur thermostat and stick it into boiling water to see wha happens that's how I checked mine before
    May 2012
    south tipperary
    wats it boosting dude? standard head gasket?
    Don't put thermostat in boiling water is fecked then
    di Member stephen180's Avatar
    Apr 2013
    flagmount, Clare
    Standard rads are really are a waste a time man and been down on power cud we related to engine temp getti n so warm wouldnt b vry good fr t
