Results 1 to 5 of 5
    di Member haydn itr's Avatar
    Dec 2010
    Default Adjusting an actuator
    Adjusting a hks actuator here just making sure do u shorten the bar to add boost or make it longer . Also it's boost at .75 want too bring it upto 1 bar 1 or 2 turns bring it up much ?
    di Member rico180's Avatar
    Feb 2011
    Formally westmeath,currently calgary, Alberta .
    i think makeing the bar longer = boost more, but dont take my word for it. best option is to do a small ajustment to it and take it for a test drive and watch your boost gauge, best to have someone with you too , while you drive and your friend can watch the gauge.do full load in 3rd/4th gear.
    Senior Member adam 9's Avatar
    Dec 2012
    offaly
    Shorten it . Keep waste gate close longer . Builds more boost
    di Member danny86's Avatar
    westmeath
    Shorten it give it a few turns bring it for a blast and check that way..
    May 2012
    south tipperary
    Shorten it Hayden , have it loose on the flap, shorten it half a turn so its just tight to get on, that shed be standard boost, then keep going back half turns til or happy .. the longer this the more the waste gate is open, less boot
