What's a good engine swap for an e30,want it for a road drifter,anyone do a swap from a e46 320 or similar,and no I don't want to jz it
m30 was a fairly common swap and can be done fairly cheaply ,all depends on you budget though,id go m3 engine
Someday I'm gonna put a 4.4 540 v8 and manual box in one of these! Expensive enough conversion, and the manual bits are hard to find. But once done will last for a long time! A lot of people tend to go for m50b25 or m52b28 in these.
I went for the 4.4 v8 option and it worked out cheaper that an m3 swap but i got a full 740 for €290 :-) so that made it a lot cheaper
The m3 swap would be more straight forward and handier u got just pick up all the m3 running gear for 1300 or so and u have everything u will need. Sayin that the v8 wasn't that hard of a conversion at all. A tuned 328 is defo your best choice if your on a small budget in my opinion
For an all rounder or car you'll use every day and best bang for you money, an M52b28 from an E36 328 with a few mods like the inlet manifild, re-map and maybe the US M3 cams is a winner hands down.
The M52s weigh only the same as a 318is engine so very nicely balanced in and E30 and with some work with mostly bolt on mods, you'd have upto 250bhp with them.
A V8 is a much cheaper conversion than the M3 imo. A V8 to fit in only needs engine mounts made or bought. The servo is abit of a pain alright but the exhaust manifolds on the M3 engine can have you dropping torque and power very easily if you get them wrong and a proper BTB manifold is over a 1000 quid.
V8 gearbox is expensive but engines are dirt cheap. A complete M3 engine and box works out the same really so 6 and half dozen as the other for actually buying the engines to start with
V8 would be a quicker car on the road anyway as they have the same power really but the V8 has a much wider and useable torque curve for a road car.
For a fast E30, gearing is probably the most important bit. Fit a 6 speed box and reasonably short diff ratio to any E30 and it'll be quicker and feel way more fun to drive. There's a 6 speed box with a 4.1 diff in my 318is and even though it only has about 150-160bhp. To drive, it feels every bit as fast as an E30 with conventional gearing and an M52 or even once told it feels as quick to be in as an M3 engined E30 when he got a spin in them back to back. Granted, I might have been pushing the IS alot harder than the M3 engined yoke
Apart from the V10, the E39 M5 V8 is the sweetest of the lot really for an E30. I know somebody who had one in their M3, then sold the engine set and went with an E46 M3 engine then but sold that again and went back to an E39 M5 engine...
He's almost finished an M5 V10 swap in it now though!
2JZ is a unreal swap if you want something different and big power.
Thats the best detailed reply you could possibly get! Are those builds on any forums I could get a look at? They sound mental!
