im just wondering what front mount pipes to use for the conversion or do I have to make up my own, and is there any way of getting the viscous fan to still work with out been to close to the rad, any help on this would be great lads
im nearly 100% sure you have to get pipes made dont think theres an off the shelf kit
as for the fan you could notch the rad into the front panel to make some space and it will work with the viscous fan
My signature picture was fricking huge - Admin
click the image to see my facebook page
would I need to strengthen the front panel or would it be sound as ill be using it for a road car? do you know do I need to change brake or clutch master cylinders? cheers for the help
I can weld all the front mount pipes 4 ya Gerry if you mark them all up
Is that u Adrian?
Ya ya get the running gear for it yt
in the process of it now, dya no where theres any? any sign of that s13 seeing the light of day ha
It's heading for drd next week hopefully then I be hoping for before Xmas
good stuff, im hoping to have this all up an going by the end of the month, would it take you long to weld up them pipes , an how much?
U mark them all up il do them in a evening for ya mite be beter getting a front facing inlet manifold will save u bringing the pipe over the top of the engine
