Results 1 to 5 of 5
    di Member jdmjimmy's Avatar
    Default Running on a jap tuned ecu
    Now that my car is up and running on a full set up off another engine turbo ,injectors,cams,ecu is the ecu going to be ok for Irish fuel is octane boost an option
    the ecu is chipped with 2 eproms for the setup as it all came from a car that had an off on track cone hit the fuel tank and damaged it must have caused fuel starvation,(oil filling catch tank) was the explanation I got.
    So just want some advice if it will be ok to run on the ecu seems to run / drive fine no hesitation flat spots etc ..
    I am going to get a wideband afr gauge if feedback is positive if not I wont be in Mondello for 30th and will be looking for aftermarket management / mapping €€€
    I dont want input like "get a nistune TDP etc etc" I just want factual advice as to whether this set up will be safe or if im going to melt shit on the 1st day out .
    I have heard of plenty of guys running setups like this on imported cars with no issues so insert help below
    Cheers
    Heres the setup
    Power Enterprise / IHI pe1420 Turbo
    4 branch & Downpipe full exhaust
    Tomei pon cams 2525lb is stamped on them
    nismo 550cc injectors
    fmic
    z32 afm
    I wouldnt drive the car personaly. Any small change from the original can make every way off like fuel pressure reg. pump. even filter. and thats notvsaying what way it was tuned before on the cas timeing.
    at the very least it get a power run done on a dyno to check. at most will cost 100e over price of melting the engine or if timeing way off over heating the turbo fucking it
    Cheers gem good info I woulndt have thought of. I may run it up to westward most local to me
    di Member juice's Avatar
    Hiroshima, Japan
    Just remember pump gas here is 97.
    Premium is 99 which all the guys use in turbo cars and tune their cars on.
    So there is a nice difference.
    LIKE AND SHARE, straight out of Japan: http://www.facebook.com/PlanetDrift
    Just get someone to check the afr and for detenation any guy that knows anything about tuning any car should be able to help you
