Page 2 of 2 FirstFirst 12
Results 11 to 20 of 29
Thread: SR20DET Misfire
    Member DaveO59's Avatar
    Oct 2012
    Galway
    Quote Originally Posted by slithertooth View Post
    Am I missing something?
    My bad, let me rephrase that.. It's got new plugs so that isin't the problem and I've swapped around the coil packs and pulled/pushed them on and off to see would the engine die slightly... I now know the coil packs are all working fine so it's not them either. To say it's not firing at all on that cylinder is probably incorrect, I know the problem is in that cylinder but what is wrong, I don't know...
    its not low enough!
    Apr 2010
    galway
    Quote Originally Posted by DaveO59 View Post
    As said have u comp tested it. It might b sparking fine but u cud have burnt valve cracked ring land etc
    Oct 2012
    Galway
    Quote Originally Posted by alan opel View Post
    Yeah 'm getting that compression tester tomorrow so I'll see what the story is there. I had the exhaust mani off there a while back and noticed a lot of carbon build up on the exhaust port of the same cylinder but thought nothing of it.. dja reckon that'd point at any of the above?
    Oct 2012
    Galway
    .....forgot to say it was running fine at the time...
    di Member gary g's Avatar
    Dec 2009
    galway
    Do a compression test had same problem, turned out piston rings where goosed, so I rebuilt it and shes runnin smooth as ever,
    Dec 2009
    galway
    Quote Originally Posted by gary g View Post
    Never mind seen you did it already, id be guessin ignitor chip,
    Oct 2012
    Galway
    Yeah Im guessing its the ignitor that's gone.. I've full continuity between the coilpacks and the ignitor and I've checked that the harness is properly connected to the ECU so I'll swap out the ignitor and see... Cheers for the suggestions lads
