Hey lads.
Has anyone came across this before with exedy triple plates... It seems to be common on various makes of cars... Just wondering if any of you have managed to improve it
Hey lads.
there is also an adjuster on the clutch pedal itself 12mm nut then screw the bar out .it can sometime make a differance to
No I mean actual triple plate clutch...the ones that are 1500 or 1600 yo yos
Good enough ha, don't know much about them but if it gives you enough clearance to select gears i wouldn't worry too much about it man, there wouldn't be much point messing with the rod if your clutch pedal is sitting level with the other 2 pedals, but you could try incase someone has been at it![]()
Well if its the case that this is the way they are, i can safely say they are over priced, over rated junk..
I had an Act heavy duty set up in car, rated for I think 700ftlbs.. It wAs a 6 puk spring centre... Pedal was light as oem.. There was the element of it being a bit on/off... But at least it was off the floor.... And it actually was more manageable..... And about 1k easier on the pocket... Regretting the change now.. Think I was brain washed..![]()
I'm running in a new engine, clutch and engine went in at same time, I've 600kms clocked up of run in miles
put a longer plunger on slave cylinder theres 2 types
I've tried longer plungers... Would you believe it makes no difference to the bite point... Its hard to understand it.
I emailed exedy and basically have been told that's the way they are. And as the plates wear the engagement point will change..
