Results 1 to 4 of 4
    di Member DannyRB25's Avatar
    Apr 2012
    Dublin
    Default Rb20det to Rb25det
    well lads, just wondering is it plug in and play or is it a lot more complicated?
    please anybody who has done the conversion id like to hear how you did it.
    i know injector 4 and 6 have to be swapped and also the vvt has to be spliced or something? i can use the exhaust side off the rb20det and also the gearbox i think.
    thanks
    Wicklow/Dublin
    done mine few months back, i ran spec1 rb25det which is more simple with wiring, and counting that you will go with spec1 here's the brief description:
    hardware:
    rb20 engine brackets+mounts
    rb20 flywheel+clutch+gearbox (rb20 and spec1 rb25 clutches are same)
    rb20 elbow+downpipe
    rb20 rad+shroud
    rb20 water temp sensor
    rb25 rad Hoses
    rb25 power steering pump and reservoir
    rb25 alternator/starter/knock sensor loom (just need to swap the steering column salenoid plug for rb20 one)
    thats about it really, all bits are just straight bolt on, for the wiring though i made myself a hybrid loom out of rb25 and rb20 looms just to have everything where its suppose to be rather then hardwiring the vvt and redoing the injector plugs, its really simple if you have some idea on what you at
    two rolls of electric tape, soldering iron, rb20+rb25 ecu pinouts and a day thats all you need for wiring!
    hope that helps!
    di Member WayneR33's Avatar
    Jan 2012
    Kildare
    I have a good rebuilt rb25 bottom end there and a new headgasket if your interested?
    Apr 2012
    Dublin
    Thanks for the feedback lads, could you forward me a price and details on the bottom end please
