Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Stupid question but where should I be checking for this?
  2. #12
    di Member jdmjimmy's Avatar
    Havent seen you on here in a while and you come along with this!
    Will make a cool car! Check all your intercooler pipes and hoses somethings got to be loose.
    The only other problem iv had like that was gunk and rust in the tank which you will not have.
  3. #13
    Quote Originally Posted by gone0-60mph View Post
    All intake pipes from the turbo to throttle body
  4. #14
    Fitted new plugs and refitted the coil packs and seems to be running 99% right now. Just a very slight miss at the top end of rev range but hardly noticeable. Will have another check around all piping and hosing this eve. It was lying idle for a while so maybe just needs a good long drive to iron stuff out.
  5. #15
    So..... the car developed a slight miss under high boost. I have done all your regular checks, plugs, leads, coil packs, fuel pump, all wiring etc etc. I couldnt seem to get to the bottom of it so decided to bring it to a local silvia specialist. He is going through it to try an get to the bottom of it. One thing he wasnt happy with was having the AFM on the opposite side to normal? I am not up to speed mechanically to give an opinion but what do people think? Is he correct in wanting to move it to other side?
