Results 1 to 9 of 9
    Default RB25DET Engine, Healthy.
    RB25 with inlet manifold, injectors, loom, ancillaries, ECU. No turbo/exhaust manifold. Comes with coilpacks but I think they could do with changing, has one snapped manifold stud (common problem on RBs and a dead easy fix while the engine is out) also has a small water leak on the inlet manifold but that is just a small rubber hose that has perished. Good healthy engine with good compression on all cylinders.
    €900 o.n.o.
    Located in Doneraile, North Cork.
    http://r32life.blogspot.com/
    Just to clear this up now it does not come with clutch/gearbox.
    Bump.
    Bump.
    Bump, may deal with cool wheels, rear geomasters, cool SR/R32 stuff etc.
    Bump.
    Bump.
    Mar 2011
    Would you sell the coilpack harness?
    Bump.
