Results 1 to 8 of 8
    di Member skelly's Avatar
    Default 1uzfe runnin gear
    in theory how much would it cost to put a 1uzfe into a ps13 ? and would anyone have the parts needed
    A lot
    Jan 2011
    Cavan
    Depends on how much of the work you can do yourself, i'd say ive mine in for less than 200 quid. Ya can pretty much buy all the parts of the shelf to fit it.
    I'd be doin nearly all of it wat box u Runnin ? And what's needed exaxtly
    Jan 2011
    Cavan
    Atm a sr box but i cant see it lasting long but it was handy to fit because its in a 180, i'l be changing it for a rb25 box or a 350z box when it gives, ya'l need flywheel(3sgte with ring gear flipped and slotted) clutch(3sgte pressure plate and sr clutch disc) spigot bush, box, prop(had to be shortened coz i pushed the engine back right up against the bulkhead, also needed a pedal box coz the servo wouldnt clear) adapter plate for the box, engine mounts, manifolds(even if ya use the standard ones they need modifying) and then wiring, simple really, my subframe also had to be modified because of moving the engine back, 180 radiator fits but you need an electric fan and a left hand side coolant bottle, think thats everything. What ya putting it in?
    Jan 2011
    Cavan
    Also fuel lines need to be replumed because the rails are in the vally of the v8 and the lines up to the rail are on the left hand side of the engine.
    Junior Member
    Oct 2012
    Co Down
    I've just removed a 1uz-fe from a Soarer this afternoon if its of any interest to you? Haven't an ad up yet as not sure what to price the bits at, but if you need any more info just ask.
    Jan 2011
    Cavan
    Realistically there only worth 3-400 euro, i bought a full toyota celisor for 500 euro and weighed in what i didnt need, got me 250 back.
