Gonna throw this up for sale, I've a full 1jz running gear which is running in my ps13 at the min so can be seen , it has very good spec and its ready to drop into any 180 or ps13, here's what's with it.. Non vvt 1jz engine complete, has 2jz front sump, all ancillaries pumps etc, loom/standard jz ecu, inlet mani, engine mounts with STI impreza mounts slot right into sr20 subframe greddy top mount 6 branch exh mani, brand new holset HX35U turbo, HKS adjustable actuator oil feed & return pipes and custom made down pipe heat wrapped, throttle cable rad pipes and other necessary bits are there also, it has an R154 manual box in mint condition with shifter, mount and prop modified for the PS, has a brand new XTD 6puk clutch and lightened flywheel fitted, barely done 5miles!! Along with it comes A brand new front mount inter cooler with piping for the jz, and a full stainless japspeed exhaust modified to cross over underneath an s body! This is very complete and the engine is just serviced with 6 new platinum plugs, filters oil and a new timing belt, tensioners and water pump, literally ready 2 drop in, A lot of money gone into this so ill be putting it up for 3000 o.n.o and see how it goes, 087 7476981 if you've any more questions, I think I've thought of everything anyway
http://
http://
http://![]()
