Results 1 to 4 of 4
    Jul 2011
    Default e36 bmw no hot or cold air from vents
    recently bought a 98 e36 coupe and i only noticed on the way home that theres no hot or cold air coming out of the vents. when i turn it upto 32 on the lcd screen no hot air same when i turn it dwn to 16 no cold air??
    anybody ever have this problem cnt see out the windscreen in the nights unless i have the windows down and it warm out
    Jul 2011
    anybody??
    Member
    Apr 2013
    Right, could be a few things.
    Need to check the blower motor under the scuttle panel, is it doing anything. (have a blower for sale if you need it)
    Also check the fuses.
    Check the HCV underneath the battery tray in the engine bay.
    Might also be an idea to flush and bleed the rad to see if that helps.
    Could be airlocked in the heater core that or the aircon may need to be recharged.
    Apr 2012
    You could go and diff the bag outa it then you'll have loadsa hot air ha
