Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 107
  1. #61
    Dec 2009
    Default Boost cut
    Is your flutter when giving her a high rev in first or no load cause mine
    Dose the same when I put the boost over 1.5 bar or slightly less
    Think it's some kind of boost cut and she fires a heap of fuel in, takes a few seconds to clear runs like shite and loads a smoke
  2. #62
    Senior Member TorqueWorks's Avatar
    May 2011
    both no load and load... but only when its cold.. once the car gets up to temp its grand never happens
    but yes it does do exactly that spluttering & choking & bellowing smoke, but sometimes it can go 5 minutes before it clears.. turning off the car for about 30 seconds normally cures it
    I dont think so much its a boost cut as the pressure sensor is fucked and not connected half the time.. nearly certain its not an ECU thing it feels more like its purely mechanical
  3. #63
    Dec 2009
    Default Tds unleash the animal
    Sounds like what's mine dose it might last longer but I do
    Kinda rev it out, may be due to the raised fuel pressure of the map I have
    And the ecu with a slight software flaw, I've had a few 325tds and they all
    Did it slightly but remapping seems to exaggerate it
  4. #64
    May 2011
    Quote Originally Posted by Duck Drift View Post
    Ah this is only becoming noticable after the last drift day.. its when its between 5000 and 6000 revs that mine starts giving bother now where it usent before.. when its a bit hotter then it doesnt happen.I think the diesel then is more viscous and goes up around the needle in the injector more freely and the needle is able to spring back easier then
  5. #65
    Member
    Mar 2013
    armagh
    mechanical pump required
    there is a guy somewhere that fitted a mercedes m pump to 325tds
  6. #66
    May 2011
    Quote Originally Posted by mantahead View Post
    not nececarily, it would be handy alright and lovely to have an inline pump...
    there is an easier choice of mechanical pump from a 524td... but none the less the only thing different between the mechanical and electrical is how the governor is opened.. the actual working mechanics of the thing are the same and completely interchangable..
    will be going for 12mm plunger & that can be got from any sort of tractor or truck with a bosch rotary pump.. and a higher lift cam plate from an Iveco cos they have one of the highest lift.. more push more diesel that all requires a MLS headgasket and a turbo aswell.. a while off that stage yet the bank account is looking shook still in college
    A bit more fancy control of the chip wouldnt go astray, maybe linearly changing with the accelerator position would be very nice might concider working on that after exams in january if I sort out this top end spluttering... oh and an electronic timing advance aswell
  7. #67
    Member
    Mar 2013
    armagh
    hi,
    i built both electronic and mechanical pumps for the merc and was tortured a bit with limp modes and rpm issues on the electronic pump.
    then i got Dieselmeken in Sweden to set the mechanical pump up, problem sorted.
    although it would be nice to have the money to go standalone ecu with electronic pump and have a nice quick rev limiter.
  8. #68
    May 2011
    hi,
    no limp mode issues for me strangely.. RPM issues I think are purely mechanical problems with this too.. Long term plan is to go & make an ecu with an arduino or something like that, I've another engine there to be doing a bit of R&D with :P
    anyways, took the injectors out yesterday.. had to make a socket to go down over them.. crude but it worked
    injector itself
    then stuck them all on this old toy.. Genuine Bosch injector tester from back in the day
    what I discovered, the injector in Cyl 1 was slightly different to the others, not leaking as such.. but the spray pattern was more focused, and the opening pressure was odd it partially opened & squirted a tiny jet unlike the other 5 which chuffed mist when touching off the opening pressure
    change that now & pull out the injector from another car instead. see what happens at 6000rpm with that changed, could make all the difference.. If not, start looking at my pre pump
  9. #69
    Loves S13s LarZ's Avatar
    Apr 2012
    Ballincollig, Co.Cork
    Arduino ECU... EPIC...
  10. #70
    May 2011
    started looking into water/meth injection heavily a few weeks ago & I've decided its worth a shot..
    anybody know about it?
    Take a read of this:
    http://www.dieselpowermag.com/tech/1...h_is_too_much/
    Why Im so interested in it is huge Horsepower & Torque gains without raising the compression ratio that much, and it lowers EGT's.... which is something I've been a little concerned about with this engine as they Reeeeeeeeeealy dont like getting too hot, hence the shorter exhaust.. and it basically steam cleans the engine...which is quite carboned up by the looks of taking out the injectors
    ***If you have no interest in water/meth injection, microcontrollers & how to DIY it stop reading now****
    the water basically absorbs some of the heat of combustion which is only a short duration in the power stroke.. then the water turns to steam for the rest of the power stroke.. steam expands quite a lot & thats how steam engines work..
    The cheaper kits are using a simple boost pressure relay that turns on the pump when the pressure reaches the set pressure. the kit starts injection at 100%
    the more advanced ones are using a pressure sensor and controlling the pump to inject between about 60% and 100% as the pressure rises or rpm rises, depending on the kit.. this maximises the power gains from the water/meth injection
    the prices of these kits are feckin mad altogether even for the basic pressure relay
    Since the control can be so basic I've decided to develop my own, as theres other advantages to making my own controller. One of the main reasons I want to do this is the diesel pump has a 5 degree timing advance solenoid
    one of the side effects of water/meth injection is a slight lag in combustion, something the timing advance solenoid can counteract be like Vaaaaaaaaaatec kicking in, except actually developing POWER not noise like hondas seem to do.
    so... what do I need:
    a Water/meth pump, something like this, the pressure can be adjusted down if needs be.. possibly the biggest expense of the whole job at around 100 quid
    http://www.alcohol-injection.com/en/...tion-pump.html
    injector nozzles, 10E each
    this sort from McMaster-Carr, not exactly sure which to go for so probably end up getting both & starting small, working up. both full cone 80 degree spray patterns.. model numbers 3178k46 and 3178k47
    http://www.mcmaster.com/#catalog/119/2074/=pw7b5g
    boost pressure sensor, I got one for 0 to 2.5 Bar with a 0 to 5V output as its sensetive enough for what I need and it future proofs it for when we get a larger turbo
    the one I chose was an MPX4250AP sensor
    optional extra: a 300psi solenoid valve to place right beside the injection nossle so it doesnt injest water when it doesnt need to
    something like this, altho more of a concern for petrol cars not exactly nececary on the diesel.. Il see!
    they come in 12v too, about 40 quid
    http://www.newark.com/gems-sensors/a...lve/dp/45M6099
    then a H bridge motor controller to be able to control the voltage to the pump from about 6ish volts to full voltage of the car, 14.4V and able to handle 10A + current draw to the pump. This is the way of controlling the quantity of water injected using PWM from a microcontroller as the boost pressure & RPM's rise
    one I have can handle 30A
    and... the microcontroller I've started playing with, an Arduino UNO R3.
    all I've being doing so far is pricking with the PWM outputs changing an LED intensity, just messing really
    I also picked up a 4 line LCD display just to make the job look fancy
    and something for another thing Ive wanted to do for a while, be able to see whats happeningwith the car from the side of the track on the laptop. plan to send stuff like engine RPM, boost pressure, throttle position, diesel tank level and water/meth injection quantity.
    I have these transmitters capable of broadcasting 1km
    http://www.dfrobot.com/index.php?rou...7#.UrTQd4XvjKo
    theres also one other thing I can do with the microcontroller, I can make the chip I have a lot more intelligent and progressive the more the accelerator pedal is pressed
