Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 107
  1. #11
    Senior Member TorqueWorks's Avatar
    May 2011
    got impatient then and wanted to see some smoke, had an initial go at starting the car & had hardship with a broken return hose on cylinder 5, airlocking constantly. damaged it while removing or re-fitting the manifold..
    Once that was sorted we got it started but running rough, air coming through from before the diesel filter, so after some head scratching we discovered that the lift pump in the tank was not going, when we gutted the interior we broke the negative wire that does be grounded to the chassis.. got that back in & within 5 seconds it started running like clockwork yet again so simple but enough to burst your head for a while
    anyways, with it running.... time to chip it up BLACK SMOKE poor Karen got a mouthfull of soot as she showed up just as we were getting it running right
    BMW 325 TDS Custom chip - YouTube
    [YOUTUBE]http://www.youtube.com/watch?v=3yPUU3qHe0o[/YOUTUBE]
    Brought it out for a spin, the power difference is MENTAL, spins in first second and third. Power band is nowflawless right to 5000 revs, and there is potential with this chip to go a touchien further.. I think we found the limit of this clutch, was half worn to start with tho we reckon.. Next is screw the boost a bit, but Lovin this smoke
  2. #12
    Senior Member grange's Avatar
    galway
    Are poor environment
    team ball bag
  3. #13
    May 2011
    Got the rear bumper on & the brakes setup through the Hydraulic handbrake
    I'll update that in a bit, but we tested it out on the slab saturday night fan belt tensioner kept hopping into service position & ended up breaking... so... we need a new one of those
    2000-3000 revs in 2nd gear not a bother Torque FTW... We did notice the smoke died away while she was under pressure but the power did not... must be using all that extra diesel, so when we screw the boost it will take a hell of a lot more... the clutch is also definitely fucked so that'll be done sharpish
    www.youtube.com/watch?v=Ngh2GHGumP8
    [YOUTUBE]www.youtube.com/watch?v=Ngh2GHGumP8[/YOUTUBE]
  4. #14
    May 2011
    anyways, the other bits we got done was the Hydraulic hadbrake... shorter throw on it than I was expecting being honest, so just change the angle Im pulling it at now to get more leverage.. anyways fitted, bled & working with no leaks thank god
    and cut a bicycle handle bar off with the grip, ovaled it & cut it up the middle to make a nice handle & then the grip slides over
    and we went up & picked up the bumper, and a few more spare tyres & alloys
    then ofcourse... a few Rings that i posted earlier.. last time we were diffing like that was with Mark G in his DX... Gone but never Forgotten :/
  5. #15
    May 2011
    Tackeled the cluch saturday, as we thought the clutch disk was well worn... and the size of the splines on the cluch, no fear of them breaking
    Ramps on the Lowloader made some job as a partial lift, didnt go too high either so the jack would be able to support the gearbox as we took it out
    Bad news however is that our dual mass flywheel is totally fucked and even warped.. so need to get a 2nd hand one and do a solid conversion on it
  6. #16
    May 2011
    Just noticed I never updated this, An original clutch cannot stick the torque that we're putting through this, so I ordered a Ceramic clutch and uprated pressure plate... waiting impatiently
    I also got this since
    pic of the Boost controller, brand new belt tensioner (keep the belt from hopping into service position.. And some Go Faster tape for a German flag
    patience ran out waiting for the ceramic clutch, went mental and made a front splitter and a rear spoiler
    gotta say I really like the splitter how it came out, finished in carbon black metallic paint
  7. #17
    Loves S13s LarZ's Avatar
    Apr 2012
    Ballincollig, Co.Cork
    Nice thread! I'd love to be this talented when it comes to working on my drift car. Can't wait to see this on track
  8. #18
    May 2011
    Quote Originally Posted by LarZ View Post
    Ya might not be waiting too long See ye sunday
    EoinK got this for us & dropped this off at the weekend Brand new lovely feel to it, gotta machine up a boss kit for it next at some stage
    Propper German Quality boost guage up to 3 Bar
    serviced it too, new filter & a good quality 5w30
  9. #19
    May 2011
    and let there be more updates to this at long last
    clutch finally arrived so prepare for more video's and updates
    The pressure plate we got was OEM, so we put in the old one cos im going to fuck this one back at them
    we didnt fit any of the bearings we got with the kit, they are supposedly shite. the release bearing was definitely a dose of shite its not a bearing atall so that went in the bin
    anyways, clutch disc lined up
    and a bit of lubricant on the splines
    got it out and going yesterday then spent 5-6 hours constant and the temperature never rose once, and only burned a half a tank of diesel. crank shaft seal doesnt seem to like the 5w30 castrol I fed it, too light :/ bit of a seep every now & then.. that's the next thing to do. so whole lot off again :/... Other than that, the bite in the clutch is actually feckin unreal & getting better as it beds in.... so we turned it a bit more still haven't screwed the boost & we've 3000 revs of usable rev range, we were diffing at 2k revs yesterday steady even as the yard dried out, infact you can see that in the vid
    anyways, video:
    BMW m51 325 TDS diesel diffing - YouTube
    [YOUTUBE]http://www.youtube.com/watch?v=edqcf4XQNEc[/YOUTUBE]
  10. #20
    May 2011
    went messing again at this yesterday
    Needed a boss kit for the steering wheel, so we cut the centre out of the old one, machined the face off on the lathe and bored the holes on the C&C milling machine to get them in the right spot. tapped them then & bolted the steering on worked out better than I was expecting
    machined face
    screwed the boost up to 1.5 Bar
    oh, and new buckety seats
    then the crank shaft seal finally caused us more hassle :/ disc, flywheel and pressure plate got contaminated..
    next step now is machine the face of the flywheel, take the step down a bit while we're at it to make the disc more on/off.. and use the new pressure plate we got
    the culprit, going to get a new seal in Abbey Seals in dublin durding the week
    oil everywhere
    anyways... sickened about the disc getting contaminated, probably get it re-lined now... always feckin something
