Results 1 to 10 of 14
    Kilkenny
    Default Rear hicas light
    Hi lads. My r32 gtst rear hicas light has started coming on after a short drive.Steerin seems fine. Any one any ideas?
    Quote Originally Posted by keith_b View Post
    pull it out and fit a hicas lockout bar, be on all the time then
    should'nt be much at all to worry about man!!
    My hicas light is on all the time, wats it mean?
    Quote Originally Posted by SUPER 180 View Post
    There's a hicas lockout/eliminator bar instead of the nissan jobbie.. gets rid of the rear wheel steering
    Kilkenny
    Ive had a look at them and im waitin on funds to buy one. Whats the best and they easy to fit?
    Should all be the same to fit lad
    The hicas light will come on if your power steering fluid is low too so check that as leaks are common.
    If you car still has the full hicas system fitted its best to change for a full eliminator kit from driftworks or conceptua tuning not just the cheap lock out bars.
    The gives better handling by removing the hicas but also gets rid of the balljoints on the rear steering arms which are a very common NCT failure.
    www.inoc.ie
    Irish Nissan Owners Club
    have one here 50 quid
    Quote Originally Posted by yowdy View Post
    thats cheap
    no point just buying the lock out bar as nissan doctor says. The ball joints are the parts of the hicas that wear easiest, and mean your back wheels turn by themselves when you accelerare/decelerate! full kit from DW is the job.
    My hicas light sometimes comes on if im on the wand for a while!
