Results 1 to 6 of 6
Thread: fuel system ?
    Default fuel system ?
    Just looking to know from lads with experience with swirl pots and aftermarket fuel system.
    If I make up an alloy fuel tank without foam or baffles and run it with a swirl pot is that ok or do I still need baffles r foam ? Id run 2 pumps I fedding the fuel to swirl pot them 1 after swirl pot feeding rail. Just looking for suggestions on it as I hear the foam isnt great in the tank with falling apart and blocking filters etc !
    di Member bart's Avatar
    laois
    most tanks dont have foam..group4 sell just the foam and its good stuff.. your feed will be from your swirl pot anyway.
    so get a good 1.5 litre one and you should be ok..
    facet lift pump and then an 044
    Team ManFoot Famous jh's Avatar
    Dungarvan, Co. Waterford
    Them 20ltr tanks GripFab are doing seem to be the job. The whole unit from your standard tank fits straight in and no need for a swirl pot or second pump needed. One of the lads got one off them and it's working mint, no surging or anything.
    Quote Originally Posted by Greg View Post
    Some say wide wheels and skinny women fear him. Some say vice versa.
    Team Manfoot
    Cheers bart.
    @john was also thinking of using standard pump and sendor etc as we can make watever tank we want to suit but wanted to get rid of that system and run external pump etc .
    Quote Originally Posted by ian g sr20 View Post
    Cheers bart.
    Why lad? I don't really see the point in it myself.
    Team Manfoot
    i like cake
    Dec 2009
    i think the idea gripfab have keeping the tank over the rear wheels of there s15 was a great idea, putting all the weight directly over the rear axel. if its an ps13/rps13 they could probably do it aswell and have it wide and not too tall so its spreads the weight!
