Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Nigey, how does the getrag line up with the sx shifter hole?
    I've a r154 going in now but might swap for the r160/161 at a later stage.
  2. #12
    Pro Driver
    The v160 box lines up a small bit further back from the origional shifter hole.... the biggese problem with changin boxes at a later date is that you'll have to get the prop re-made and you'll have to get a v160 clutch as the r154 one won't work.......
    The supra also runs a 3.2 diff so unless you change to something similar your gearing will be crazy short kinda defeating the point of running the 6speed box!
