Results 11 to 20 of 23
    MEATH
    Default Tyre changer/balancer
    Bought from tyre care in cavan for 2.8k in January.
    Second hand but in excellent condition.
    Has full helper arm for low profile / run flats
    Also has built in tank for wall blaster etc, nice extras, easily used for daily work.
    Beats the shit out of some of the muck out there.
    Comes with Redmount elec balancer in tippy top condition
    some commercial details on machine
    The machine is equipped with a double-acting bead breaking cylinder and an oversize bead breaker blade to prevent damage to tyres and rims.
    •Alloy rims are handled particularly gently as the mounting head is provided with plastic protectors. The one-part mounting head can be adjusted vertically and horizontally in spaced-apart position relative to the rim.
    •The pneumatic tilt-back post and the four ergonomic pedals add much to user friendly operation.
    •Accurate and quick operation is guaranteed by the self-centring four-jaw turntable controlled by two clamping cylinders and the pneumatically locked post.
    •Certified by wdk
    •With pneumatic mounting tool MH 320 pro and plus kit (standard equipment) for handling of UHP and run-fl at tyre systems (additional optional adaptors required for PAX and CSR tyres).
    •Also available as A22-24 racing without MH 320 pro and plus kit (not certified).
    •Outer clamping range of up to 24“ for wheels of large diameter
    •The pedal-controlled two-speed turntable (3-ph versions only) and the horizontal arm supported on rollers make tyre service even quicker.
    •With the pedal-controlled infl ation system the tyres are inflated quickly and safely
    google Boxer tyre macine with helper arm and you'll see it.
    will upload pics soon
    2200e
