so i failed the NCT on the 2 front bushons of the rear sub-frame.
now iv jacked it up and took a look and they look fine now, not alot of movement in them when jacked up but there is a bit,
if i get locking collars it will lock the sub-frame up in place wont it?
then when the car is jacked up the sub-frame will stay up and there will be no movement correct?
and then when i take the test again ill be ok right?
