Results 1 to 9 of 9
Thread: S14 extralock
    Jun 2012
    Limerick
    Default S14 extralock
    Well lads fitted extralock hubs to the 14 and looks like the tyres are almost rubbing the arches and will if the car goes over bumps what's a fast way to sort this, I don't want to do major cutting as I am out in mondello Monday so something fast! Pictures would be great!
    Cill Dara
    You could try some spacers to move the wheels out. The only proper option is to get the lump hammer out and hit back the areas it's rubbing!
    Jun 2012
    Limerick
    Il do a bit of bashing tonight and see how I get on! Other than that I might put the 16s on the front
    Cork
    Wheel spacers or some new shoes with less offset.
    Depending on your wheels, 25mm should see you clear of them.
    Just reading your post there again, is it the inner or outer arch your getting caught on?
    Jun 2012
    Limerick
    It's the inner chassis leg inside where the battery is one the drivers side and the collant bottle on the other so I don't know how much hammering I will get away with, I have spacers on already they are twenty fives to clear my brakes!
    Smaller walled tires up front. Im gonna have to do the same with mine need to fit 215/35/18's on mine
    Jun 2012
    Limerick
    Jesus I'm not too bad so ha ha il get out my biggest persuader so and see how I can on! Thanks Lads!
    i like cake
    Dec 2009
    im running 18's on mine, it was rubbing on the front arch tub and at the rear of the arch aswell on full lock standard lock. bit of bashing to the arch tub and remember to check your wiring harness and tie it out of harms way before its too late!
    Jun 2012
    Limerick
    Job done bashed the s**t out of it! can't wait for Mondello now on Monday!
